It is currently Thu Jul 17, 2025 11:36 pm
PostPosted: Fri Oct 20, 2006 6:49 am
Does anyone use a pin router for inlay? The folks who cut my fret markers offer a pin router template for cutting the fretbds. I'm wondering if anyone has a homemade one, or ideas. Pictures would be great if you have any!
PostPosted: Fri Oct 20, 2006 7:01 am
I built one using ball bearing drawer glides, one set in the X and one set in the Y axis. I do not have the plans for it but could take pics this weekend if I get the chance. I am going to rebuild with linear bearing blocks and polised rods instead of the drawer glidesMichaelP39010.6685763889
PostPosted: Fri Oct 20, 2006 7:06 am
Thanks michael, would greatly appreciate that
Mark, check the Tools and Jigs section of the OLF, or follow THIS link to a great Pin router Keith MacKenzie made. I have personally used this jig and it works fantastic..LanceK39010.6715856481
PostPosted: Fri Oct 20, 2006 7:18 am
Lance, thanks for the help. Do you know if there are any plans out there to build this?
PostPosted: Fri Oct 20, 2006 7:24 am
Mark I forgot about that being in the jigs section. That is what I built min from. but I did not use plans.
PostPosted: Fri Oct 20, 2006 7:26 am
No plans, but I think Keith has a ton of pictures some where on line.
PostPosted: Fri Oct 20, 2006 8:58 am
There were some plans in one of the wood working magazines within the past year. I'll take a look, I think I have a pdf of plans or something.
PostPosted: Fri Oct 20, 2006 9:02 am
found it. Popular Mechanics
PostPosted: Fri Oct 20, 2006 9:19 am
Thanks Rod! Nice article.
PostPosted: Fri Oct 20, 2006 9:39 am
The one by Keith MacKenzie shown in Lances link looks good.
Has anyone used a pin router to rout a saddle slot in a bridge? It looks like an operation that could be done by guiding the pin along an angled fence.
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Fri Oct 20, 2006 9:41 am
Great article Rod, Thanks
PostPosted: Fri Oct 20, 2006 9:48 am
I still have this info online and will answer any questions. I have since switched to the John Hall type high speed pencil air tool (56000 rpm) but it also works well with a good dremmel.
http://home.mindspring.com/~keithmackenzie7/
PostPosted: Fri Oct 20, 2006 12:12 pm
I know (at least I think I know) that Mark Swanson cuts his truss rod slots with a pin router. Maybe he uses it for the saddle slot too.
I like the idea of repeatability on the headstock inlay and fretboard inlays, that would be fun.
PostPosted: Fri Oct 20, 2006 1:28 pm
Keith, I'm going to be inlaying detailed fret markers which is why I'm building this. is there a lot of play using these computer brackets?
PostPosted: Fri Oct 20, 2006 1:30 pm
Rod -- great article.   K2CNC sells motor mounts for various size routers through Ebay or their website. I picked up one of these for my the Duplicarver I plan on making. Porter Cable Router Mount
PostPosted: Fri Oct 20, 2006 3:16 pm
If you want to see an application of K2CNC's bracket used with a router check out this ebay item: http://cgi.ebay.com/LINEAR-MOTION-SLIDING-ROUTER-DEWALT-BOSC H-PORTER-CABLE_W0QQitemZ300039227464QQihZ020QQcategoryZ20781 QQcmdZViewItem
I bought it on eBay a few weeks ago with the Bosch router and it is a very interesting setup. I am using it for routing an inlay strip in joined backs. Oce of the other thins it is good for is repetitive slots in that the router head slides along the bar. I am planning on using this ability to route tail wedges by building my tail jig into the same table I have the rail system.
A true pin router has the advantage of having a retractable pin (in the case of the Onsrud Inverted Pin Router) or a plunging router head (as in the popular mechanics plan above).
PostPosted: Fri Oct 20, 2006 6:58 pm
Mark,
Side to side there is almost no play and the cavities come out very precise. As I stated in the original post I used a .028 guide pin and an .031 bit to allow clearance for the inlay to fit in the cavity. I know Lance was letting his daughter run the tool to cut that cool Kragenbrink headstock. There is some up down play but as long as you don't push up or down as you are using the tool it is quite satisfactory for maintaining depth of cut. Play with some scrap to get the feel of it.
When using .032 bits you must slow down the feed rate so that you don't break the bit. On larger inlays I use a larger pin/bit set to hog out the bulk of the material then come back with a small set to pick up the fine detail. The main reason I changed to a 56000 rpm air grinder was to increase the feed rate of the smaller bits.
Make sure your rails are dead parallel or your table will not move smoothly.
Hope this answers your concerns and good luck.
PostPosted: Fri Oct 20, 2006 7:08 pm
Just another note.
Since that first model I put the router and pin setup on a hinged plate that allows them both to lift at the same time and lower to a stop, making the plunge cut a little less nerve racking.
PostPosted: Fri Oct 20, 2006 11:29 pm
Thanks so much for your help keith and everyone else. Any luthier who has not found this site has no idea what their missing. There's a bunch of great folks here!
PostPosted: Sat Oct 21, 2006 4:33 pm
Hey, thanks Rod, i filed this article, will build me a new jig, cool!
